v3.5
Plug-in to retrieve Mobile Alerts data from compatible Lacrosse sensors.
! Attention, before purchase, you need either a kit with MA10001 gateway, or if you have the gateway, compatible sensors, check the compatibility page on the Mobile Alerts page ! You can also find them on the Lacrosse page in the "Connected Objects" menu *
Note: The plugin is used to install the script and one type of sensor at a time! examples:
If you come from version v3.4 you no longer have access to the data, Mobile Alerts having blocked PHP calls, this new version has therefore removed the possibility of determining the duration of the cache, this is now fixed at 30' and not editable
To overcome this blockage, you must now enter your User Agent in VAR2, contact me in PM
You will therefore also have to modify the call URL which becomes
http://localhost/script/?exec=lacrosse.php&phoneid=[VAR1]&useragent=[VAR2]&langue=[VAR3]
! Warning: If VAR2 spreads (only one sensor to modify), it is not the same for the URL, it will be necessary for each sensor to change the word cacheduration by the word useragent!
Quick setup
** Installation chapter **
You are advised to read the prerequisites before going to the Installation Chapter
The Master Sensor
The "Cache Time" Master Sensor is the "parent" of all Mobile Alerts devices. They are therefore grouped into channels and have in common the parameters Var [1,2 & 3] and Polling (chapter Group). This Master Sensor will tell you the name of the sensor that last called the Mobile Alerts server and the time of this call: the other sensors using the cache. There is an English presentation in the installation choice !
Warning: before deleting a device, unassociate it (Attach to) otherwise you will delete all the devices in the parent/child group.
We will find, on Amazon or mainly in Germany, the same products under the TechnoLine - Mobile Alerts brands with the same references & TFA Dostmann (which produces the shell for outdoor thermometer of article MA10250) WEATHERHUB SmartHome.
For the usefulness of the gateway, the advantages of Lacrosse / Techno-Line / Conrad Connect sensors, their references, see the links provided (Mobile Alerts - Lacrosse - Discussion of the script in the Eedomus forum).
The plugin only offers the creation of one type of device at a time including for the Master Sensor which is only to be installed once and only once! (chapter Installation). Once a device of a given type has been created and its configuration completed and saved, you will have to duplicate it to install another of the same type to fill in only the personalized information concerning the latter: name, part, XPath and leave it rest of the information as is.
Smartphone ID, User Agent and Language are only indicated when creating the Master Sensor (Cache Time). When creating a Sensor, these values no longer have to be entered.
You can, before purchase, see an example of HTML data by going to the page of Luc Trullemans, an exceptional meteorologist (RTL, expeditions, Solar Impulse ...) now retired, in the Observation menu (the first Huppertzberg link is a Mobile Alerts link).
You can also install the smartphone app and add the following test sensors:
| Sensor | ID |
| Temp/Hygro | 0301548CBC4A |
| WInd Sensor | 0B002FA7C3D3 |
| Rain Sensor | 08004EA0B619 |
| Air quality monitor | 050809F04EE6 |
| H2O | 04419803C1B0 |
| Contact | 107EEEB46F02 |
You have a Mobile Alerts gateway and at least one compatible sensor or control unit:
the default units at installation are:
| Sensor | Unit |
| Temperature | °C |
| Rainfall | mm |
| Wind | km/h |
To view other units:
You must change them in the "Settings" tab of the Smartphone App, then you will indicate this in "Unit" of the configuration of the sensor concerned.
The configuration window will appear, indicate the following values:
Complete the configuration:
The "Cache Time" Master Sensor contains the name of the calling device and will be used to create the group of Mobile Alerts Sensors which will all be considered as channels of this Master Sensor, each modification of a single sensor on VAR (1 to 3) and Polling (which must always be equal to 30) will be passed on to all the others, to satisfy the requirement of identical data (see explanations on the cache), the sensors will therefore all have to be attached to the Master Sensor (Expert Parameters). You can change the name of the Master Sensor (default: "Cache Time"), but not its XPath!
The cache makes it possible to interrogate only one sensor to recover all of the data (this sensor and the update time are indicated in the Master Sensor), the other sensors, in the interval between the cache duration (30'), interrogate the latter.
NB: in the event of an acquisition error, during the query to the server, the duration of the cache is immediately increased by 30': all the other sensors will read the cache, unchanged, until the next acquisition . This significantly reduces error notifications, and alleviates the load on the server during return to service.
At installation, you have these choices of description of the compass (16 directions)
Please note, these are descriptions, not values, the value will always be International.
For classic letterbox use: this sensor, linked to an opening sensor, will indicate either,
You can then create a rule to determine if, for example, a mailbox has been (opened and) closed and at what time.
Example, test the value "since yesterday", if it is different, the box has been opened.
NB: the value will only update after updating the Master Sensor, then after its own update!
To locate the desired value, then the Tags that frame it:
// tag (usually predetermined)// Name of sensor / tag//__anemometre_huppertzberg__482m_/rafale_X (X = 1, 2, ...) in this case, the name of the sensor alone is sufficient.
Be careful to locate the name of the sensor, the incrementing being done in order, a temperature sensor then a temperature and hygrometry sensor will be named respectively: temperature_1, temperature_2, hygrometre_1, always check in the XML before enter the XPath. Do not change the Master Sensor predefined XPath.
These devices are the most suitable for weather data, extreme temperatures (-40 ° C + 60 ° C), battery savings and are 868 Mz (500mw) therefore having a theoretical range of 100 meters. They also benefit from a relatively low cost (including gateway). This plugin which takes up the script published on the eedomus forum was inspired by a publication (published in 2017) on the Jeedom forum and the basis for its programming was carried out by merguez07. All updates are from thrymartin.
